I washed my engine at the car wash to replace the valve cover gaskets. It ran fine untill it warmed up. It runs great cold. As soon as it warms up it boggs and surges bad at cruise speed. If I tromp it to the bottom it runs like a scallded dog untill I go back to running steady. I changed out the TIF modual with one off an old distributor. Base timing is at 10 degrees and advance is working. The throttle position sensor, KOEO, has 5.1 volts on the orange wire. 1.05 volts varying smoothly to 4.53 at WOT on the green wire. Reading the codes, I only had a 23 in continuous memory and a 74 engine running. Any suggestions are appricated.
Roy
Roy
