It says in my Haynes manual regarding suspension that caster is not a routine adjustment and that it only affects the self return characteristics of the steering system. Is that true?
Also is it measured from vertical? or centerline of the ball joint axis?
The way this manual makes it sound is that camber and toe are the only important issues with tire wear?
It also says caster is adjusted by adding or subtracting shims at the rear of the lower suspension arms? Where are those on my 2wd?
I'm hoping 4x4Junkie will chime in soon? Thanks, just trying to learn how to properly set up the front end here before I buy parts and get totally into something here. I've also considered your body lift idea at this point too Junkie...hahaha
Allen
Allen
