ericp
- Jun 2, 2008
- Automatic
wow this is making me crazy. i have my 96 ranger with 4.0 in it. it has 184000 miles and has a few things i need to figure how.
1. Truck starts and runs great but after driving and engine is hot i turn it off. when i come back around 30 minutes later to start back up, idles very rough and starts to die unless i give it gas. you can hear in the exhaust pipe that it is missfiring badly. will not stop until i start to drive, it will smooth out slowly. i have changed IACV and nothing. cleaned Mass Air Flow Sensor. new plugs, and fuel filter. (seems problem only occurs in warmer weather) Any ideas?
2. Check Engine Light. Over the past year that i have owned this truck, all of the oxygen sensors have gone bad. most recently bank 1 sensor 1 went out. after i changed it, i left battery off for a while. almost immediatly light came back on. had it checked and came out with codes for the same sensor and bank 1 sensor 2, which i've already changed. both under warranty i changed them and still the same thing. CEL is always on. Any ideas? (since all of this i've driven over 1000 miles, so it would have reset if it was going to)
