- Aug 1, 2009
- Marquette Mi
- Automatic
...im pretty sure the 89 ranger had the TTB front end?
6 inches is to high, and with the steering and leaf springs its all about opinion, to build i pre runner essentially you wont want any of your parts. you have an 89 ranger? you don't want the IFS it has, you want different gearing its a huge list. like the guy above said go to a pre runner website
there is nothing wrong with the IFS he has except for its a 4wd. Beams are awesome if you're on a budget.
Thats where i got that, i got confused for a second.
89 4x4 Ranger...
This is for the best bang out of your buck.
Front suspension.
-Cut and turned beams. (lower ball joint extension.)
-Ranger lift coils or jeep coils. (PM me I have some)
-Extended radius arms.
-Some decent 10" 2.5" remote resi shocks.
-Custom coil bucket (DUG Fab sells a weld it yourself kit for cheap)
If you do run the Jeep coils, your shock valving will be a little different. Yes the coils are softer but they hold the weight of the truck and have a longer free length.
Also.. Be sure to box the beams in as much as possibly and lay over lay plates around the ball joint area..
For the rear.
-The chevy leafs work nice although they should be arched a bit more than they came stock. You can build a frankenstein leaf pack and get it work just fine. Some guys on here have put together these packs, look around.
-Flipped and extended shackle. This is going to allow the leafs to lay out nice at full bump. It will keep you from dearching the leaf pack. It also helps with droop and plunge..
-Upper truss on the 8.8. (stay away from welding to the center section) If you search you can find decent truss jobs on these rear ends.
-16" 2.5" Shocks work well back here.
-Get some weight over the back axle, spares, tools, jack, bronco II tank... etc..![]()
