Want to put Fiberglass Fenders on 03 XLT 4x4
TRanger03
Wondering what you guys thought about Fiberglass Fenders. I was thinking about putting them on my 2003 Ranger xlt 4x4 so i could fit 33-35 inch tires. I was also considering cranking the tbars and maybe even a body lift. The truck needs to be good on and off road. Any thoughts or oppinions welcome.
Do whatever you want. IMO, dont get the fenders unless you need them. If you crank your t-bars your ride on the road will suffer, unless you like being on a pogo stick
I would do the narrowest bulge (3" usually) fenders you can get, combined with a slight torsion crank and a shackle out back will get you plenty of room for 33's and you may even be able to tuck 35's.
body lifts are GAY is it a street pavement princess mall crawler or a weekend warrior? that is the diecidind factor do what you want im drunk
if you want it to be good on and off road, don't do the body lift and definitely don't crank the torsion bars. fiberglass fenders are alright, but will make you look like a poser if you have no lift at all.
Get larger diameter aftermarket torsion bars.
They will support the new ride height with less pre-load.
The problem with cranking stock torsions is you have to pre load the crap out of them in turn making them ride like hell.. Plus their life span will suffer.
fabtech lift spindles they make them for the 4x4 im sure, get the shackles in the back and get the fiberglass in the front ... caution ! next is bumpers, shocks, lights ... you wont stop
Lift spindles only work for 2wds, but with glass and leveled he should be able to tuck 35s with properly backspaced rims.
