walkthrough or instruction manual?
Guagke
does anyone have a walkthrough or instruction manual on how to install 5.13 gears and lockright lockers into d35 ttb with reverse rotation and on a 8.8. im a journeyman carpenter and not a mechanic by trade but its either weld front and rear and no gears or actually do it right since i put alot of time and money into this truck.
There should be some links right here within the Axles FAQ that explains gear setup in detail.
It's a pretty intricate process, requiring many special tools (which can try your patience too if you're a 1st-timer). However it can be a very rewarding experience once you're finished. The savings (not including any needed tool purchases) can exceed $500, maybe even $600 for two installs, plus you'll acquire a ton of new knowledge about it to put under your hat :icon_thumby:
