Once engine and trans were in place, I wanted to get a bearing on space in the engine bay area, so I mocked up a fender and the header panel. The radiator we got for this truck is a CBR 31x16”, which is 3” shorter in height than I’m used to using on full-size trucks and you can still see it stuck above the header panel by a decent amount. This resulted in me cutting the front of the frame off and bringing it down lower for the radiator to sit properly in the truck once I started on the engine cage structure. There was some time spent trying to figure out what I wanted to do for layout on the engine cage, my main things were I needed to build it around knowing it’s getting a bigger power plant later, so the center needed to be as open as possible and if I could I wanted it to look different than what I typically see on these I-beam trucks. The main structure comes out wide from the A pillars, instead of the center windshield tubes, giving a lot of space in the center of the truck and also giving it a more aggressive look diving into the front portion. The radiator tucks nicely into the engine cage, right in its little pocket in the frame rail. I didn’t want to have this thing sitting outside the main engine cage structure and have it possibly get unwanted damage if there was some sort of front end collision so this was the ticket.
Once the main structure was there, I started playing with shock layout as well as firewall layout and engine cage lacing tubes. These all need to be thought out together, at least in my opinion, to make sure everything works together properly and you aren’t shooting your self in the foot somewhere later. With this truck being so narrow in width, packaging shocks was kinda tricky at full compression/full lock situations. To add ontop of that, because this is running a conventional 3 peice clip and not some sickkkyyyyy raptor clip, the height constraints to the underside of the hood are a lot tighter as well so getting the bypass to clear at full bump took a little time moving mock up tabs around to get the angles correct. That is why this shock package has so much rake to it as well, it’s just to get everything to clear under the hood. You can also see my super custom shock supports I use too while I mount shocks
another thing to note too, all the shock pivots are running dirtking weld washers making the bolt holes extra thiccc and simplifying the shock mounts to where I don’t need to run some crazy looking overlay. This is my go to setup now, sometimes more simple is better and in this case with shock mounts I think it’s the ticket
