Saw your recent YouTube on the ranger, and it absolutely amazing. I have been around all types of prerunners and this is one of the best ones I have ever seen. Are you gonna keep the 93 front end? When the v8 is installed will that be a manual or auto transmission? Listen to what you said about making all three pedals custom made, wondering the v8 will be a manual transmission. What exhaust setup are looking to use? What gear ratio is being used in this masterpiece?
Thanks dude. Yes! This truck is keeping the conventional 3 peice 90's front clip. It already has a fiberglass factory replica hood and 4.5" wider fiberglass fenders that was used on it previously and im building everything around that. The raptor conversion stuff that alot of these trucks get now is a no go on anything I build haha. When the time comes for the v8, it will have a built T400 behind it, no more manual. The only reason its staying that for now is because thats what the truck came with. In the dirt having a manual is more of a handful because you need to keep a hand on the shifter at speed through bumps or its gonna neutral bomb itself. Having a hand off the wheel is not the most ideal thing at speed, so for now it kinda is what it is. Once real power is thrown at it, youll need to have both hands on the wheel to control whats happening at all times. The pedal setup will be all one off hand made stuff to fit around the packaging constraints of what the truck is now, and then when it goes to a v8 ill redo a gas and brake pedal to be a little bigger and more spread apart since it will be missing the 3rd pedal at that point! Gearing on this thing as of right now is 5:43's in the 3rd
