Vin# help
F66 - f600 4wd
E - 361 V8
V - Kentucky Assembly Plant
C50011 - production numbers, this will give you the year and build month.
I’m just going by memory, it should be pretty accurate.
And my other question is who's 4x4 conversion would this be marmon Harrington or a napco
I guess I don't understand the c50011 how can I determine the year
Post a picture of it if you can. The C usually designates which 100000 Number it was, the 50011 the number it was built.
For example if A was 100,000, B was 200,000 and C was 300,000 yours would be the 350,011 made. This is just an example.
You can figure out the year by finding a serial number list. Itll say something like numbers 250000-300000 were built in 1971 or whatever.
C could also be code for the model year or decade. Its hard to say. Im not super familar with the medium duty truck stuff.
If it has a 361 i can tell you its late 50'a at the oldest and early 80s at newest (81 i believe)
If the 4wd wasnt factory in those years (once again, not sure, but if @snoranger is right on the vin then it should be factory) its more then likely its a MH conversion.
