Vibration...
superdave1
Just install pilot bearing, clutch/PP and slave. I had the flywheel turned and used LUK parts kit. Now I have a vibration. I checked the driveshaft and I did mark it and reinstalled it the same. The trans came out of a Mazda 4000 and it had 140,000 miles on it. I took the top off and the gears and all looked okay, and the bearings were not very sloppy. You think the flywheel is out of balance. This motor, 4.0 is balanced internally, right? I also have a #%^&% header exhaust leak that I cannot locate. Seems like the crossover pipe at the 2 flanges don't duite line up. They did not leak before, checked the gaskets last night and they are not upside down or backwards.
SD
