vent window replacement-92 f150
predator
elk mound, wis
hey guys so i finally got a replacement window for the f150, it came from a junkyard and has the track and everything with it...how do i replace it?? is there a way to do it with out taking the door apart?? never had to do this but now i finally get to get rid of the duct tape that is there right now.
you have to take the door panel off. There will be a bolt towards the bottom of the track behind the door panel. There is also screws on the top of the door. You'll need to have the window down to remove it.
thanks zman...will have to do that soon, starting to get freakin cold!
