Vent temperature control issue
Bryanp66
Hey guys,
I know I have a blend door issue because my max a/c isn't working. Now that it's cooling off and I'm not using the a/c I'm noticing the air out of the vents is warmer than the outside air even with the temp dial all the way to cold and I'm just using the fan. It's not hot, but noticeably warmer than the outside air. Is this related to that blend door or a control valve problem?
Bryan
Otherwise, the temp control dial regulates the
temperature fine
