jasongind
So i replaced the heads on my '88 2.9L Ranger. got it all back togehter, tried to start it and noticed it was "popping" through the intake. So i went and adjust the valve lash as follows:
-find TDC cylender #1 (pulled spark plug stuck finger in hole and rotated the crack with a wrench till the air blow out then stopped), verify rotor is pointing to cylender 1
-lossened rockers adjuster bolts then tightend to .005 inch intake and exhaust
-moved on and repeated steps on cylinders 4,2,5,3 and then 6.
then i reassembled eveything, cranked it and same thing popping.
now i read the Chilton and it says to adjust till rocker is bearly touching spring then go 1.5 turns about 2mm. My thing is this if .005 inch is to tight and causes popping 1.5 turns/2mm is going to be way to tight. Unless Im confused somewhere.
Any info/suggestions would be greatly appreciated. Its rainy up here in WA state and im getting tired riding my motorcycle already lol.
-Jason
-Jason
