Vacuum Test 20inHG and reved 22inHG (good ?)
mlunsford
At idle my 4.0L has 20 HG/in and when I rev it the vaccuum drops for a second then the vacuum goes up to about 22HG/in. Does this sound about right ?
I am trying to make sure my cats are not creating back-pressure.
That's a golden result.
Very nice.
As long as the needle doesn't have a jitter or periodic low.
It's definitely not a restricted exhaust.
Thanks,
Nice link too. I would recommend that link be put on the tech page!!
Most of the time, a quick jab of the throttle from idle won't show a thing if your cats are clogged unless they're TOTALLY clogged - a steady 1/3+ throttle will actually show you more clearly if they're clogged or another restriction exists in your exhaust system by a slowly dropping vacuum reading.
Bird
