Vacuum line disconnected
tntbrian
I'm army wits end! There is a vacuum line that has became disconnected on the female end that has suction on it. It is threaded up the casing of the heater core on passenger side. Where does the end that is disconnected go!!! I've looked all day and used every manual I could find.
maybe the power booster? or where the power booster connects D: not sure though
Opposite ends of the truck dude.
does your selecter for the air hand heat work. sounds like your talken for the vacume from the black ball on the passanger fender if you pop your passanger side kick panel off you you will see a white and black vacume line that goes throught the fire wall that runs under the blower onthe the front side in the engine bay. you will have to get to it through the fender well just pop the plastic tabs off and look mine came un hooked a few days ago. one goes up to the top of the motor and the other goes down to a vacum canister on that plastic inner fender i think after the vacume line goes through the fire wall it is gray under the hood.
