shanep1987
- Mar 19, 2013
- Automatic
I have been having a rough idle issue for the last few weeks after the truck gets warm. I think the only thing left that i havent replaced or ruled out is a vacuum leak.
I can hear a slight hiss around the intake pcv area on the drivers side. I have went through 2 cans of carb cleaner around the engine/hoses including that area trying to listen for a change in idle. Another thing is i pulled the pcv valve and shook it(it ratlles) and also put my finger over the hole in the intake there was no change in idle. Also put my finger over the valve itself and felt vacuum but there was no change in the rough idle. Normal?
I have also hooked a hose to the brake booster and blew smoke in it, found no leaks other than the breather hose from intake which i replaced.
What am i missing?
What am i missing?
