Vigilante
- Dec 24, 2009
- Sacramento, CA
- 2.5 (4 Cylinder)
- Tire Size
- 235 75
Aren't they great? lol
So, every time I think I have solved a problem, I seem to find something else that could be contributing to the larger portion. Now for instance, I notice a vaccum hose in the cab that goes through the firewall (above and just to the left [looking towards the front of the car] of the accelerator pedal) and connects to the rear facing vaccum point. This hose ran through my firewall and was wound up under the dash and was plugged by a rather large bolt. My Chilton's doesn't tell me much on vaccums and what it does the image is far too small to read.
Ok, have to throw this in too.
At the front of the air intake manifold (towards the front of the vehicle) there are 2 vaccum ports. One is for the Mass air flow sensor, the other is for the air cleaner box (I think?). My car idles much smoother when these are disconnected in park or neutral but when the car is in gear it runs rough until I plug in ONLY the Mass air flow sensor.
So heres the first pic showing my main vaccum hub on the drivers side of the engine at the back, closest to the cab. The blue painters tape is to mark the port that the 'unknown' vaccum hose goes to. It was easier to just plug it here than to connect it and plug the line.
So this is where the 'unknown' vaccum hose goes through the firewall. At the point where the hose goes through this reinforced rubber component, the vaccum hose itself is reinforced with a copper tube that is roughly 4 inches long and sticks out about 2 inches and goes into this reinforced point through the firewall.
And lastly, this is where the 'unknown' hose comes through the firewall in the cab. The metal component on the right is the accelerator and the black rubber boot is the steering column. You can see the hose goes out of the picture but comes back around into the pic. I did this to try to show that the hose was not cut. It is a thicker black hose with a yellow stripe on it. I cannot find anything in my vaccum diagrams or in my manuals that indicate what it may be. I am under the impression that it could be Air Conditioning or something?
She idles around 900 rpm for about 20 seconds and then starts to bogg and the rpms climb just so she can keep herself alive. I believe I am running lean on the fuel because when I open up the throttle she will die, or she clears up but then shuts down when the rpms reach 3500. The Idle Air Controller I removed and it checked out to manual specs (but it is an original Ford part). And the Mass Air Flow sensor was replaced, but when I unplug the MAF sensor from its vaccum port on the front of the intake manifold, it runs better than when it is connected. I have no check engine light while the car is running either.
And is there any way to tell which vaccum hose goes where and what exactly they do? I would like to write this down and draw myself a better picture than what it is I have been able to find.
This morning I tried a new approach. I plugged all the vaccum ports (besides the ones that I know are going to their respective locations) as well as the main air intake, and she idled beautifully at 800 rpm for more than a minute before she got rough and died. I've had vaccum problems on my old Explorer, but it was never as bad as this and I am still at a loss to figure out what exactly is going on with it, lol.
