Panama is right, it's an extremely simple system. If you don't find any cracks or bent lines, just feel for vacuum all along starting at the manifold, then the orb, then the output of the orb (an idiot had switched my two lines on the orb when I bought my truck), then that will feed directly under the airbox and come through the passenger side of the firewall, check there, also check the heater control valve hose (comes out of the bottom of the airbox). If every one of these connections is good and you feel vacuum everywhere, it's a problem in your vacuum harness under the dash. Hopefully this is kind of what you were looking for.
