Hi guys, tried doing a search and couldn't come up with a difinative answer.
Can you use a tachometer that was originally in a V6 equipped ranger (late 1987) on a 4 cyl engine?
I'm guessing the V6 wiring will expect a 3 pulse per revolution signal, while the 4 popper wants to see 2PPM.
I know on similar era F-series trucks, there is a second ground that must be connected to distinguish between V8 and 6cyl gassers. In that case, ford labelled it "G8" to indicate the second ground required for 8cyl engines.
Do rangers have something similar? Or did ford make a separate tach assemblies for 6 and 4 cyl engines?
I already test drove it and the readings seem bang on and very steady.
