Utah peeps!!!
Well now ya pic nazi! I put a few up. One of the progress with the spring swap, and one for my Avatar with my '06 front clip. Good enough? lol!
leave the bed off i like that look
Well, how am I supposed to keep the ladies from falling through the rails? Naw, bed's going back on when its all done. Anyone have some new rear leaf spring hangers? Damn things are rusted through and I might as well replace 'em while I'm here. My warehouse in SLC doesn't stock them...they only have 1 front :(
found out what was wrong with the vibration in my drive shaft. The yoke was loose. Tightened it up and all is super quiet now.
Hit my diff cover in moab. Now it leaks all over the driveway. Wife is not happy.
every bII that i've had, had problems with the rear d/s bolts loosening, then it would howl a little bit at high speeds. that's how i knew it was time to get under there and tighten them again.
It wasn't my driveshaft. It was my pinion nut that was loose. Not sure how that happened, but all better now. Except for the oil leak from my diff cover.
I once again have windows. Not sure if I like it or not.
the added integrity can't hurt
You say that like integrity is a good thing. Ithink I found a full rollbar for a prerunner on saturday. Not sure on price yet, but with a little nodding it will
work like s champ. How's that for itegrity. Plus I can hook my exhaust to it when I run it out the top of the bronco.:headbang:
man i've been using mine as a daily driver since i don't have a company car now.......man its a gas hog
So is mine and it's a V6. I decided I better drive my Mustang for the next little bit before it decides to snow. It gets a lot better mpg's than the Ranger.
For some reason it didn't take me as long to get to work today.......:icon_confused:
yeah mine took $10 to go to midvale and back
Not to mention roasting your feet. :eek::eek::eek:
how did you know that? did i tell you that was a problem? :icon_confused:
its actually not that bad because i patched most of it but one small part that i left open because i needed to do away with the floor heat vent so i figured directing a little hot air from the engine bay on to the floor wouldn't hurt. so i guess my feet are warmer than the rest of me but my truck never came with a/c and it was 95 degrees yesterday......all of me was warm
No. Ive been watching the psychic channel. Just kidding. Yes you told me
about it. You covered it with some abs plastic.
