Yes, O2 sensors can't work until they get above 650degF, so need to heat up first, but only maybe 3 to 5 minutes on cold start, engine temp can still be at 1/4 on the gauge, not fully warmed up, but CHOKE is still on so engine would still run a bit Rich
Test for O2 is WOT(wide open throttle), after warm up go for a drive at 65mph when starts to cut out, press gas pedal to the floor, WOT
Computer ignores O2 sensor at that time and goes for max power, fuel economy is out the window, lol
If engine starts to run better then yes change O2 sensor
O2 sensors do wear out, they run out of the chemical used to detect oxygen in the exhaust, 150k miles or so, you will see MPG slowly go down as engine runs richer from failing O2
Yes, fuel injectors that sit with fuel in them can get plugged up as the fuel degrades, it changes into a varnish like sludge
