grey ghost
did ford use two difrent wire harnesses for their trucks?
i got the factory fog light switch and installed it inside the cab when i went pooking around under the hood i noticed that i didn't have the plugs anywere for the fog lights and then looking in the master fuse panel under the hood there wasn't a place for a 15 amp fuse in slot 31 like the owner's manual stated?
if it helps the truck is a 2004 regular cab with nothing added exept ac. didn't come with fogs.. do i need a diffrent wire harness to get the factory switch to work or what could i change to make it work. i didn't want to hack holes in the truck and wanted to keep the "clean " factory look..
