U no stealla me truck
RDC
Anti theft
sorry bout the diagram, it is too small to read the print. If you have a alarm system that has a amp rated relay if not you can use it to activate a relay, you can use it instead of the toggle switch, or you can use a remote switch with a relay in line . Be sure to hide which ever one you use. I suggest you keep the stock fuel-cut off switch if you do any off roading.
