- Mar 8, 2008
- Age
- 61
I have an 86 ranger (3 inch body lift so all u-joint angle are factory) and 32 inch tires. This is driven twice a week (160 miles) to work and back, then very minor wheeling. all three back drive line u-joints go out at about the same time, not breaking just "drying up, the little bit of grease that were in the 2 caps on drive line side was COOKED bad, the rear end one is always the worse, then the transfer case u-joint (still has grease just cooked and play) then the center u-joint (same as transfer case just less play.) The carrier bearing is new, and so is the center slip yoke. I know the factory size is tiny on those u-joints. I know the biggest tires I should run are 30/9.5, but the Dana 28 is not having trouble. If it was the same u-joint i would say problem at that spot (had a problem with slip yoke, that was another set of 3.) if it was manufacturer i would say not at roughly same time, and more than likely break not start to dry up and get play for all of them.
They are Napa auto parts u-joints, greasable. i could not find non-greasable (mixed reviews on greasable versus non-greasable). I tried to get some ford factory u-joints but after shipping they would have been well over 130.00. and more than likely break in another 8,000 miles.
I don't trash my truck, and I have been in thick mud with the last three u-joints, but not the first set.
I have re grounded the engine to the frame, and frame to the cab and bed with 10 gauge wire (someone told me that if the engine lost ground and was running through the drive train it could cause them to overheat.) I know electricity can do strange things(being an electrician for 6.5 years(household))
Second thought from an old timer ford guy is that the tires 32's are causing the joints to overheat; both times I replaced the rear u-joint the diff side had dried out totally while the drive line side was just burned grease.
Any help would be appreciated, getting very frustrated with this ongoing problem.
