Is a 6 degree operating angle too much for a standard 1330 single cardan rear driveshaft to run at? I know spicer recommends no more than 3 degrees, but my setup is at 6 degrees and I don't want a major vibration from it. I have a little play in the slip shaft that I have to fix (if I grab both ends and twist the splines are a hair loose back and forth) and I don't want to get this shaft repaired if I will have a bad vibration from the 6 degree operating angle.
