Two Questions
Wildcat
I have a 1999 Ford Ranger 4X4 with 3.0 Liter engine. First question I continue to get a check engine light and the codes indicates EGR valve. I have replaced the EGR valve twice, replaced the EGR solenoid and continue to get the same check engine light and code. Any ideas? Also the vehicle only has 46,000 miles on it I have also changed the spark plugs and have seen a decrease in fuel economy in this vehicle. Thank You
This is the Welcome Section, but thank god you posted a question here.
Welcome to TRS.
Welcome to the forums.
To further answer your question, you need to give a little more info. What are the exact codes that you are getting?
