two brake questions ASAP!!!!
crawlin91
OTOTM Winner
Solid Axle Swap
Crawlorado
My front driverside stock fitting has two hoses that run into it, the passenger side only has one. I got the 2piece lines from the tech library.
1)HOW DO I ASSEMBLE IT???
this pic shows one the line that ran into the top of the stock fitting hooked to my new lines. There is another line behind the mount that you cant see that also goes into the fitting.
Im using the stock parking break lines in the 8.8 drums. Its been a real PITA and I cant seem to stretch the spring/cable over the tab in the drum.
2)IS THERE A SPECIAL TOOL USED FOR THIS?
also the hardline fittings dont fit the 8.8 drum :dunno:
The second line crosses over to the passenger side to supply the line on that side.
You need to use a T block there since you are using the 2 piece lines from the tech library. If you were using a set of aftermarket lines, it would have the fitting for the second line.
I posted a reply in the General Forum concerning your parking brake...but I'll repeat it here in case you don't see it...
Disconnect the parking brake cable at the connector in front of the axel...once you have everything installed and the drums back on, reconnect the cable and you should be good to go...
yeah sorry. dont mean to be a pain in the ass posting all over the place, just need my daily driver back. Its getting awfully cold here.
