Twin turbo 3.0
Pense
I was wondering if i could get any information on how to turbocharge my 3.0 liter in my ranger. any help would be apprectiated thanks
custom pistons, crankshaft, custom connecting rods,4.0 tb, custom fuel rails, 5.0 injectors, custome injector wiring harness, fuel pump, 5.0 lifters, complete valve job, open ports and polish, ext. throw in a v-8 and turbo charge it.
Brilliant.....:nono:
You've never turbo'd anything in your life and you spewing crap that you once saw on TV?
Look around in the 4.0L section there are a couple DIY turbo setups you can look through. The 3.0L won't be much different. 90% of the problem is turbo sizing and packaging, when trying to twin turbo.
i would sugest just using a single turbo. I would just use a turbocoupe T3. remove the airbox and relocated anything else that is on the passenger side of the motor and you will find a gaping hole to stuff a turbo there. No need to flipp manifolds and or build custom headers simply U turn the exhaust after the Y pipe to route the exhaust back up front to the turbo then squeeze a downpipe back past the motor. Keep the bosot below 10lbs on the stock motor and you should be fine as long as the setup is tuned correctly. You will need a tuning device like SCT/Moates/Tweecer/Sniper along with bigger injectors and fuel pump. A turbo ranger 3.0 TT has been done this one is in brazil.http://www.youtube.com/watch?v=x5rV7-DlfeM
You want a twin turbo 3.0? Swap in a 2jzgtte from a supra..... lol. Or you can pick up an NA 2jz and turbo it. Much better engine than a vulcan. Sorry I used to have an 89 supra....
jackass i got the info from a guy that spent 5k to twin his 98 ranger 3.0 and said it was a waste of time. told me to be smart and throw in a v-8 and turbo it. dont watch tv its useless all it does is make me non-productive.
your spewing shit you dont know. i have lots of experience on turbo charging and supercharging real engines like supra engines and 2000hp drag engines. worked at a shop building racing and blown street engines. go **** yourself.
im curious where u worked.
:icon_rofl::icon_rofl::icon_rofl::thefinger:
This has been entertaining morning reading. Thanks rngrdngr. I always enjoy reading a good BS post.
This is awesome...
some people just want something to say they have it. It may be more cost effective for me to swap in a 4.0 or a 5.0 than supercharge my 3.0 but thats what i want. Twins on a 3.0 will be kinda awkward because you will need tiny turbo's.
Given that you're 20, exactly how long did you work at this shop? And where is this place? I can't find ANY reference to them doing a search.
I curious to know what type of motor a 'supra engine' is.
Is that a manufacturer? or a certain design?
I've never heard of a supra engine.
:thefinger:
