twin stick
What's a twin stick?
It is a mod done to a gear-driven transfer case that allows independent shifting of gear range and 4x4 mode. So you could put your case in 2-wheel LO range for example. Or if you were sideways on a hill, you could put the rear in neutral and front in HI and "swing" yourself around.
It can't be done to the BW135X series cases found in RBVs because they're chain-driven.
yeah np 205s or dana 300 are comon twin sticks.my powerwagon has a np205 with a twin stick.i think it is the badest thing in 4x4! id like to find a way to swap one into the ranger i just bought, but i gess its just a ranger... cant do to much hevey dudy mods:bawling:
You can swap a D300 into your Ranger.
You'd have to buy a flip kit.
Twin stick that thing and put some 4:1 gears in and you're good to go. Of course you could buy and Atlas for not much more.
umm... is a flip kit for pasenger to driver side drop?
do you mean twin sticks as in manual tranny and manual tcase or 2 sticks just for the tcase
twin stick
Transfer case.
One stick controls the front axle Hi-N-Lo, the other is for the rear axle Hi-N-Lo.
now boys and girls with the borg warners meat DADY 205 you cant break it me and my dad have droped his 77 6000pd power wagon right down on a boulder in the quary one day broke the 727 but not the 205....o0o0o and evan my 4x4 budy has a old willeys jeep out back his hous with a 300 in it he might let it go for 200 or trade for my 340 heads. Have you seen any 300 in ranger swaps? if you have let me know id like to study that
well never mind the willeys is a dana 18 so.... il look more
this site is a good one for any one interested in this
http://homepage.mac.com/rv6a/d300.html
Good article powerwagon. He saved about $1000 this way. (I priced out a 2-speed Atlas on Advance Adapters, and it was $2400 with 4:1 gearing)
I assume you'd have to build an adapter plate to hook a 300 up to an RBV? The input on most 300s is 23-spline, so it will match up there, but I'm not sure about bolting it up.
well im thinking obout trying to use a bronco dana 20 wuts the out put spline on the 88 mazda 5 speed? i forgot to count when i had it apart. the 300 looks like more work. for now ill work on 35/44 convershion up front and a 8 3/4 in rear.
