2.3L ('83-'97) Turns over but won’t start 4 cylinder 2.3 L Ford ranger xl
Crested Butte Colorado
Hi,
I stopped at a stop sign and when I pushed the accelerator the engine died. Turning the ignition results in the engine turning over but it will not start. It sounded like fuel was not getting to the engine. I knew that the truck had never really been worked on when I bought it. It has 150,000+ miles on it, the fuel pump and fuel filter had never been replaced so that’s where I started. I replaced the fuel pump and the in line fuel filter. I tried to start the vehicle and had the same issue as before. I checked the pressure on the fuel line using the Schaefer valve and it has pressure, checked the return line to the gas tank and gas flows when pump is active. Next I grounded all of the spark plug lines to check for spark, all were good, I replaced all of the spark plugs. Still won’t start. I used an obd scanner to check for codes and it did not return any codes scanner read PASS no codes. What else could be the issue? Thank you.
Sounds like only thing left is injectors? Would be a long shot for all of them to go out at same time. No idea where the other end of the connector goes…. Relay, fuse, computer?
Check the timing belt, could be broken or jumped time. They are supposed to be changed every 80K miles.
+1 ^^^^
Broken Timing belt is a common, and overlooked, issue on 2.3l Lima engines
No engine damage occurs, just a Crank but No Start issue
Look behind timing belt cover
The big giveaway on a broken or skipped tooth on a timing belt is an uneven sound when cranking, it'll have dead spots when turning or no resistance... but that's where I'd go as well, if it has spark and fuel pressure it should run if the cam is turning...
Thanks everyone, I pulled the cover and the timing belt is loose and cracked, pretty sure once I see the whole belt I will find a tear. Any tips for replacing a timing belt?
It’s pretty straight forward. Just take off the stuff in front of it. The hardest part for me was figuring out how to get the plastic cover off. An ac line was in the worst spot ever to get that thing off
Google: 1996 ford ranger 2.3l timing belt replacement video
Several are there
2.3l/2.5l are the same, 1995-2001
1994 and earlier are the same mechanically BUT...........different crank sensors
2.3l was used from 1974 to 1997 in several Ford Models, all used the same timing belt set up
Several are there
I’ve also read about the functionality of the accessory pulley. mine is just an idler so I didn’t dig too awful deep, but at some point the oil pump is driven off of it. That may or may not need to be timed as well. I think cali rangers had the cam sensor on the accessory pulley so timing it is essential on those.
AUX gear always drove the oil pump, and distributor when it had one, up to 1988
Yes, 1989 to 1994 2.3l may or may not have a Cam Sensor, the AUX gear is what the Cam Sensor used, so if it had a Cam sensor then AUX gear needed to be timed, if no Cam sensor then it didn't
1995 to 2001 2.3l and 2.5l all had Cam Sensors
AUX and Cam gears are the same size, and interchangeable, so each one had BOTH timing marks, a triangle and a diamond, oriented for the key way on that gear
One of the issues is a 1/2 worn diamond looks like a.............................you guessed it, a triangle, lol
