- Sep 19, 2025
- Age
- 55
- Williamsburg
- State - Country
- VA - USA
- Other
- 2007 Volkawagen MK5 Rabbit 2.5
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Manual
- Total Lift
- None yet ;-)
- Tire Size
- 265/75/16
- My credo
- Facta Non Verba
When you repair or replace that use Dicor self-leveling sealant.I think I may have found the source of my water leak in the nose.
There's this (TV?) antenna front center above the galley hatch.
Well I climbed up where I could see the base of the antenna and found this.
Sealant (caulk?) around the base of the antenna is torn/missing, and it looks like the base is a little loose too. That would match with what I was seeing. The wide round antenna is somewhat going to block the rain from hitting it when sitting stationary, and what water is running off the roof there is still likely to channel around it. When driving down the road, the wind is going to blow water right into that gap. Looks like remove, clean, and reseal that gap will probably take care of that leak.
Next up I need to pull the window unit AC. It works, seems to do pretty good job of cooling, though I need to test it on a truly hot day. If you are familiar with window units, you know that they create condensation. Georgia summers are hot and can be very humid. That means running the AC a lot and a lot of condensation. There's no drain for said condensation, so if it creates enough it's going to overflow the bottom of the housing, out case louvers, right into the floor. Need to figure out adding a drain into the case and through the floor of the compartment. Possibly also some better vent fans for that compartment. Currently just two 120mm computer case fans. Not a great design for the AC, but looks better than a window unit through the wall. Eventually with modifications I will make a catch pan for this area as well, that way if it does overflow the case, it's not damaging the floor. No pictures of that right, but will get some when I start on it.
Don't use "regular" caulk.
Find any places where your roof or other horizontal surfaces have openings, scrape back as much of the existing sealant as you can. Clean. The. Reseal with Dicor.
