turbo questions
not enoughsmoke
pulaski tn
1993
198
I bought a 1993 ranger and. I am gonna turbo it I was readin about everyone running about forged pistion are yall mostly talkin about just factory turbo pistons and are yall using stock head bolts or arp head studs
I'm running weisco forged pistons and only at 10psi of boost. My rods have ARP bolts in them though.
Would stock pistons from a factory turbo motor work or not what do u think
yea they should work but i wouldnt go crazy on booost
Yes, stock turbo pistons and rods will hold up to a lot. I ran 25+ psi on they. They held up fine. The block however...
well what would u say would be ur safe range on boost and whats a good max rpm that wouldnt hurt but still be good to run ?
Stick with the stock rev limiter of 6500 (la3) and about 20 psi.
Aright got a parts list 1993 2.3 ranger new forged pistons an rings, rod bearings and mains,arp rod bolts,stock thunderbird turbo and manifold and accel 36lbs injectors high impedance did I for get any thing?
What ECU are you going to run, and how do you plan to tune it?
You will need a lot of misc. tubing for oil, water and air plumbing.
I was gonna run the ranger ecu and I will have the misc stuff. Iwas lookin to run about 15psi or 10 psi
