- Aug 7, 2007
- Troll land
- 4.0 V6
- Tire Size
- 42
Ok so I wanted to go with boost and was thinking about going from the 2.9 to the turbo 2.3 in my wheelin rig. After finding out all the detail on that I think I might go a different way.
Draw through propane.
Now the questions.
What distributor can I use to get mechanical or vacuum advance on the 2.9? Would pull the injectors TIG weld the holes shut and run with no electrical controls.
Also I have a complet turbo setup from a 2.3. Do you think this will be to small for the 2.9 or 2.8 if the goal is the have a fast spooling turbo with the respective v6 maxing at 5000 RPM?
Thoughts and suggestions? Have done some searching and propane and forced induction seem like they are damn well paired with each other.
Now the questions.
