TheRob
- Jul 23, 2009
If I am using extra injectors mounted in the cold side IC pipe to supply fuel in boost, then a BOV (not a BPV) would be the correct method of equalizing pressure during a throttle close, right? I used to turbo cars with MAP systems, but with the MAF systems used on the 2.5L Ranger, it would seem that a BPV is the right answer if you're using something like a Megasquirt or a chip or something like that. However, if you're using a completely separate set of injectors that are run off its own MAP sensor, then a BOV would work correctly I think. If a BPV were used with an extra injector setup, then closing the throttle under boost would potentially lead to a rich condition as the MAF would be seeing seeing the extra air from the BPV firing, but that air wouldn't be going into the engine. Am I thinking about this right, or does someone have any experience with such a setup?
Thanks,
-Rob
Thanks,
-Rob
