Turbine Speed Sensor Help
My92Ranger
Got a 97 B4000 4.0 auto 2wd.
Went to get it inspected and it failed emissions for a p0715 turbine speed sensor circuit malfunction.
I know this is inside the transmission and I will have to pull the transmission if it is the sensor but I want to test it. Does anyone know which wires at the main transmission connector go to this? Id like to OHM them at the connector rather than drop the pan and try to find a 2 wire plug somewhere inside the pan (any info I have found in a search doesnt show a pic or anything of where the plug is nor have any of my searches came up with the wiring colors)
Would appreciate any help. Thanks
