TTB Thrust Washer Alternative?
I've got a 92 Ranger with the Dana 35 TTB. I can't seem to find a direct replacement for the thrust washers at the end of my front axles. The ones located under the front hubs. Does anyone know if they are still hiding somewhere or if this kit from, I'm guessing a Ranger with IFS and a Dana 35, will work? If this kit will work how does the three parts stack when installed. I'm pretty sure all I had was a splined thrust washer and a snap ring.
That's probably F57Z-3B458-A. It works and came on one of my axles, although I think it's easier to break. IIRC it's thrust washer, spacer, splined washer on the outside.
If you want the fat ones and you can't find FOTZ-3B458-A, call Randy's Ring & Pinion (not online) and ask if they still have WRN 37891. It's not splined all the way around, but it fits. Last time I bought them was 3 year ago, though.
I just ordered some earlier this year. Might have been from Jeffs Bronco Graveyard. I don’t remember exactly. Either there or Rock Auto
Has anyone upgraded the retaining ring, instead of using the original c-shaped style? If so, what did you use?
snap ring.
jeffs bronco grave yard too.
torque king
