ttb drop brakets- camber adjustment bushing
eclipseguy
Oak harbor, wa
so i have a delima. do i use ttb drop brakets or just get the camber adjustment bushing. My personal thought is that the camber adjustment bushing might put excessive stress on the knuckle. But the ttb drop brakets also pose a threat of punching a hole threw the diff.... so im stuck on what i really want to do. would like some imput. I already have the drop brakets. but i have a shop in town that can put on the bushings and alignment. thaks for the time
how much lift? bushings are only good for around 1.5-2" of lift without changing brackets.
do you have a real lift brackets or do you have a plate? the plates are notorious for poking holes in diffs, but not actual lift brackets.
you'll need it aligned after you lift it so you will probably want the brackets and the bushings both. adjustment bushings aren't gonna put any more stress on the ball joint or knuckle than there normally is.
i have about 4 inches of lift. so sounds like i both. and what i have is a braket with a plate on it..
