TTB binding
Northidahotrailblazer
10+ Year Member
Truck of Month
Northern Idaho
8 inches
37"
Anyone had this problem, I’ve had to raise mine up, different EB coils, got. My camber set to .5 both sides, toe is a little out now, but it helps. When I turn onto pavement, or give it a bunch of throttle the front end comes up and I get way to much positive camber and it won’t come back down. It stays like that until I hit the brakes hard or back up. On gravel it doesn’t do it. My steering is perfectly straight but it’s not crazy out of wack. I kinda think my steering is getting bound up and not causing the beams to go back up. I’ve been fighting this thing getting the alignment to where I’m currently at has been a nightmare. But I think it’s close,
I think it’s my steering binding up on the beams. I ordered the true 4” drop that should help.
Yeah, if your steering linkages aren't flat you're likely going to have a hard time, mine's maybe 3/4" above flat and it works pretty good... I know the FA600 pitman arm is a hard bullet to bite but I'm glad I got it.
