Alright been doing some searching and not a lot has come up.
I have the skyjacker 6" Lift. I also have the FA600 drop pitman arm installed. Not crazy about the angle of the steering. Plus the Joint that connect the two rods hits the rear most rod at sharp turns. How is the pitman arm supposed to be situated? Anybody have pictures with this setup. Also, my steering wheel is almost 180 degrees off if that helps.
