try again
cervidog
Is there a way to turn on the fuel pump so I can get old gas out fo the tank? Itryed using air to blow the gas out but,there must be a check valve in the fuel line.I am trying to not drop the fuel tank if I don`t have to.
The ignition key turns the pump on..
Big Jim
ya but isn`t there a thing that shuts it off for a couple.reasons?I would like to run it long enough to get all of it out.
Disconnect the fuel line at the filter and stick the end in a gas can. Then go to the fuse panel under the hood. Locate the fuel pump relay. remove relay. get a jumper wire. put the jumper ends in I believe ends 30 and 87...look on the side of the relay and it should show you what two terminals to jump to get power. either way, jump the two together and woolah
Thats what I`m talkin about.Thanks guys.
