marty_rk
- Jan 2, 2012
- Automatic
I have looked everywhere,
First clutch pedal frozen. reservoir was empty, did a bench top bleed, then hooked up the system and bled the system by gravity and cycled through 4oz worth. the pump will pump with bleed open. When bleed screw is closed, it locks up.
What am I missing, it is currently still stuck in neutral. It shifts fine into all gears
