Cooter199
my truck will die once in a while and then wont start for about 5 minutes and then it will start like nothing happened. what could cause this?
check all the wires and clean the connectors with elect cleaner and put dielectric on when you put them together. Sand all the grounds metal to metal. Are there any stored codes check for codes it is real hard to diagnose intermittent faults I hope the code will point you but not always the case.
kimcrwbr1, You are so right about the connections. As computer tech for many years there were so many times when intermittent problems were fixed just by reseating connectors. Have you found a particular brand or type of cleaner that really removes the oxidation from the connectors? Mostly I have used contact cleaner from Radio Shack but the contacts don't look much different than before. It seems like they would get brighter once the oxidation was removed. I noticed they have a two step cleaner now but it is fairly expensive. I appreciate any suggestions you may have.
