jodom15sc
ok, well i have had a few posts on here with beginning stages of tonights aftermath,
1. temp gauge started to move around, replaced thermostat, 1st one ive ever done, but my buddy helped me and he has done alot of them, fine for few days, then gauge started to messed up and go crazy, saw on here may have been air in the system but would be ok,
2. then lifted hood, saw, radiator hose to thermostat housing was shriveling up, but the weather warmed up and i ran my truck for awhile one day, and it went back to normal...assumed i fixed it
3. came out of walmart one night, saw antifreeze on the ground, popped radiator cap off and looked in, couldnt see fluid, put some in, but noticed radiator...RUST, looks like pure rust,....put some fluid in and planned to drain it soon as i had time...made sure i put cap back on good
4. noticed a leak but couldnt find it, tonight driving home noticed some steam coming up from under hood, soon as i can i pull over, pop the hood, radiator cap pretty much blew off, with antifreeze spewing out, along with pouring out of reservoir tank....fluid all over the road, motor, and soaked the pad on the underside of the hood
so im assuming it spewed out pretty dam bad
I know this may all sound weird but im not very mechanically inclined, the most i do is oil changes, some fluid changes, and a little bit of electrical...tomorrow only thing open is a shitty pepboys,....ima take it over there, get new raidator cap, coolant/radiator flush and presppurisezed, and new thermostat put in....
any other opinions on what im doing most likely doing/done wrong or should get done?
