reno
- Jan 18, 2008
I asked Jim a few days ago to hold the Answer key to these, but have not heard from him as of yet, Perhaps Makg might want to do the Honors?. I figured I would post these quizzes,you answer to the best of your ability,then in a couple of days, I will post the answers and move on to the next chapter. If I can figure out how to break this pdf file down,then i will post the current chapter we just had a pop quiz to in a zip file for you to read, this way you will know where your own weak points are and know what to mainly read on. This is why i decided not to post the chapter to read first.
This is a Cut & Paste....no Alterations what so ever.
So here goes:
1. The term TDC refers to
a. the engine exhaust system
b. rolling resistance of tires
c. crankshaft position
corresponding to a piston at
the top of its stroke
d. the distance between
headlights
2. The distributor is
a. a rotary switch that connects
the ignition coil to the various
spark plugs
b. a system for smoothing tire
load
c. a system that generates the
spark in the cylinders
d. a section of the drivetrain
3. The air–fuel ratio is
a. the rate at which combustible
products enter the engine
b. the ratio of the mass of air to
the mass of fuel in a cylinder
before ignition
c. the ratio of gasoline to air in
the exhaust pipe
d. intake air and fuel velocity
ratio
4. Ignition normally occurs
a. at BDC
b. at TDC
c. just after TDC
d. just before TDC
5. Most automobile engines are
a. large and heavy
b. gasoline-fueled, spark-ignited,
liquid-cooled internal
combustion type
c. unable to run at elevations
that are below sea level
d. able to operate with any fuel
other than gasoline
6. An exhaust valve is
a. a hole in the cylinder head
b. a mechanism for releasing the
combustion products from
the cylinder
c. the pipe connecting the
engine to the muffler
d. a small opening at the bottom
of a piston
7. Power is produced during
a. intake stroke
b. compression stroke
c. power stroke
d. exhaust stroke
8. The transmission
a. converts rotary to linear
motion
b. optimizes the transfer of
engine power to the drivetrain
c. has four forward speeds and
one reverse
d. automatically selects the
highest gear ratio
9. The suspension system
a. partially isolates the body of a
car from road vibrations
b. holds the wheels on the axles
c. suspends the driver and
passengers
d. consists of four springs
10. The camshaft
a. operates the intake and
exhaust valves
b. rotates at the same speed as
the crankshaft
c. has connecting rods attached
to it
d. opens and closes the breaker
points
11. An SI engine is
a. a type of internal combustion
engine
b. a Stirling engine
c. always fuel injected
d. none of the above
12. The intake system refers to
a. the carburetor
b. a set of tubes
c. a system of valves, pipes, and
throttle plates
d. the components of an engine
through which fuel and air are
supplied to the engine
Good Luck, Answer sheet will be given on Mon Morning....
So here goes:
headlights
spark plugs
load
before ignition
the exhaust pipe
ratio
a. at BDC
b. at TDC
c. just after TDC
d. just before TDC
a. large and heavy
combustion type
other than gasoline
the cylinder
of a piston
a. intake stroke
c. power stroke
d. exhaust stroke
8. The transmission
motion
one reverse
highest gear ratio
passengers
10. The camshaft
exhaust valves
the crankshaft
to it
points
11. An SI engine is
engine
a. the carburetor
b. a set of tubes
throttle plates
