trouble with pcm
Ramirezsergio63
Mecca. CA, US
I was cruising down in my 95 ranger 5 speed when it suddenly out of nowhere everything shut down. I pulled over and like five minutes later it started again like nothing. After that, it made the same thing like every two weeks until one day I waited like an hour:annoyed: and didnt start and a friend of mine changed the pcm relay and started. It seems to be doing the same shit but to be able to start I need to hit the relay black box thats on the drivers side under the hood. When I hit it, it makes like some electrical noise as if there were sparks but i see no sparks, after that it starts. has anyone experienced this problem before?...If so, how can it be fixed?:dunno:
sounds like a bad connection. you need to check where the relay is plugged into and make sure it is fitting in there tight enough.
