- Nov 2, 2007
- Statesville,NC
Had a customer of mine work on a ranger today. same problem as everyone else. turns out the pilot bearing was bad in that one.
maybe this is the problem with mine. i have a hard time going into first at a stop. sometimes while downshifting to second it'll grind. and when im driving as the rpms climb and im about to shift i'll hear a chirping noise. also when i down shift or let off the gas you hear a faint rattle(may not actually be faint as i have a cherrybomb and compared to that everything sounds faint lol)
edit: also recently when i (but not often) shift in to first from a stop and let off the clutch it'll buck and bog a little bit and then make a popping noise after that it drives normal through every other gear
