allen227
- Jan 1, 2008
I am starting a project to remove the the transmission and find a leak and possibly change the clutch. I see the hy. line and master cylinder but am a little unsure how to disconnect the line at either the bell housing or the master cylinder? If some one can give me some detailed instruction on how to disconnect that line it would hlp. I havent done a clutch on a rear wheel drive b4 so I am learning as I go. I plan on leaving the transfer case attached for the job, to remove the front drive shaft does it just slide into the transfer case or is there something I am missing? also How do you remove the shifter? I have the boot loose but it is kinda in the way. I would like to get the shifter know off to remove the boot but cant seem to figure it out?
Any other help or tricks would be helpful as well thx.
89 bronco II xlt 4x4 5 speed manual with manual shifting transfer case.
