Transmisson failure
Michaelolson88
5+ Year Member
Seattle
Hey yall,
Happened this weekend to me. My truck is primarily a weekender and took it out camping last weekend for its longest drive in about 6 months (150 miles roundtrip) I was leaving our campspot and had a real tough Bang shift from first to second. didnt think much of it but about 20 miles later noticed my rpms going a little wonkey. I parked at a gas station and went to leave and it wouldnt go into reverse. after that the gears were shifting horribly late and O/D light started flashing. I had the transmission rebuilt about 45k miles ago and havent had any other issues. Im assuming valve body replacement is neeeded as the transmission fluid was clean and had plenty in it.
1999 4.0 xlt 5r55e
Should note that i went out the next day and now its shifting into reverse and all other gears totally fine
Hows your speedometer acting?
The flashing overdrive light is basically the transmissions check engine. I dont know if it stores codes or not but it would be worth a plug in to see.
The fact its ok today seems its most likely a speed sensor or some other electrical issue over something mechanical.
Speedometer was fine and acted normal. I have a habit of removing my battery cable after drives so i dont kill the batter. Didnt occur to me that the O/D flashing would have told me the issue when reading the code (doh) I think ill have to try and get it to flash again so i can read the codes.
On my Mustaang when I was having troubles, got the flashing OD light. When I turned it off, it reset. So no, they do not store codes. You gotta take it somewhere and get it scanned without shutting it off. I have a friend here with a transmission shop. When my Moostang was acting up, I drove it there and he scanned it before shutting it off. Resulted in having to have it rebuilt. The code was for the lockup torque converter failing to lock.
On both my Lightning and Ranger, I generally leave OD off in town. When the lockup converter locks, it feels like it shifted. And the tach needle gets very inactive. Before lockup, the slightest thing causes the needle to move. After lockup, it lost freezes in place. On the Mudstain, the needle never did that. It just kept jumping around like a red rubber ball.
Pulling the cable will reset it.
I would probably also use a trickle charger on the battery rather then unhooking it.
I had a 94 E150 that would always flash like that too. Finally after numerous trips to various trans shops as well as the dealer it went off but never was quite right.
just updating for others searching the forum. Went out on another drive and got some rough shifting. At this point im replacing all 6 solenoids with new transmission filter and gasket. Will update on progress and if this fixes the issue.
