i was wondering if you notice any smoke from the exhaust when it revs but will not go?
This what I have, nothing in the pan and no gears at all. The only noise was a snap, just like somebody had knocked it out of gear. Another couple days on the Talon and i'll let you know for sure when I get it checked apart. Oh, to be young again and able to move about.
This is exactly what happened to me. Driving one day and heard a "snap" and it rolled to a stop. Engine would rev but no forward or reverse. Found the splines in the torque converter were gone. The shaft itself was fine. I tore the trans down anyway and found the overdrive drum was eating into the star washer but this wasn't the problem but I am glad I caught it anyway.
If your going to do it yourself it wouldn't hurt to install a shift kit and some of the Sonnax updates. Also don't forget to replace the flexplate to crank spacer, mine was cracked and its supposed to be a common problem. You'll also need a pump alignment tool specific to this transmission if you want to check the pump. The pump bushing is specific to the bellhousing since its installed undersize and machined to size so don't remove it unless you want to pay someone $50 to install and machine a new one.
That sounds like my problem. I lucked out over this weekend. I picked up a 2.9l, a4ld, transfer case, driveshaft and front bumper for $175. It's still all hooked together and has 90,000 on it. The man rolled his Ranger, the insurance paid it off and he just wanted rid of the stuff left over.
I'm going to swap the tranny with mine and then take my time rebuilding mine and if and when the other one goes bad I'll have one. The 2.9l has the newer better type heads, so I may rebuild it too. My truck's body is A-1 and I plan on keeping it until the end of time. I'm 64 now and I figure with a new trans and engine and with the limited amount I drive, this should last me at least until I hit 100 years old.
When I get my trans out and apart I'll post what I find. I want to thank everyone on here for all the help. This is a nice community you have here.
