Is incorrect gearing (ie. 3.73's with 33" tires) bad for the transmission? For some reason I thought I saw someone say that on TRS before, but I might be going crazy.
Does that even apply to stock gearing with maybe 2 inch bigger tire size? When would it start impacting tranny? I know my stock explorer tires are easy to 1 hand curl and my 265/75/16 start getting harder..
Yep it's fine to a point. You can think of it as the higher the engine revs before it starts off the hotter it's gonna get (like pillen said about towing all the time) If your turning bigger tires it takes more oomph to get them started rolling and such. Regearing is a good idea depending on how much bigger than stock your running (or plan to run). If you don't quite wanna drop the necessary money yet to regear for slightly larger than stock you should definitely invest in a trans cooler. In my opinion if you stay in low range (low speed/ higher rpm's=heat) more than once in a blue moon with an auto tranny or do tow alot for that matter, I think you should have a good aftermarket cooler anyway regardless of tire size.
